3 Inch Roll Bars for RC4WD Blazer Pickup Conversions
RexRacer19
Let me 3D print that...
I have designed a couple of old school 3 inch roll bars that work with RC4WD Blazer pickup conversions. There is a single tube version and a double tube version. Both feature two mounting tabs on the top that can be used for mounting lights with M3 screws.
Single tube version:
https://www.shapeways.com/product/Y...wd-blazer-pickup-conversion?optionId=65443211
Double tube version:
https://www.shapeways.com/product/C...wd-blazer-pickup-conversion?optionId=65455422
Here are some pics of the single tube version on my personal build:
Installation is simple. Put the bar in the location you want to install it and find the center of the mounting flange using a couple of marks. I would recommend starting with the front two legs first, then once they are mounted with screws, locate the rear legs and mark them.
Drill the center mark with a 1/8 inch (3.2mm) bit.
Finally, attach the roll bar with (4) M3X8 screws from underneath. They will thread into the holes, but be careful not to over-tighten them.
TROPIX
I am in the process of building A scx10 ii Blazer k5 build and be interested in any prototypes of inner fenders!!! ::2thumbs
