3d printed wheels
car54
Looking at wheels that are 52mm diameter and 25mm wide. I'm wondering if 1.9 tires will fit these wheels ok? Or should I steer clear of them, thanks.
JunkGTZ
52 mm is really just over 2" so a 2.15 or 2.2 tire. 25 mm is about 1" so if you looking at slicks or on road, your best bet might be 1/10 buggy on-road tires. I've been looking for similar inside diameter tires but wider - 1.5" or about 38 mm. It also depends on how tall a side wall you want too. The on-road 1/10 buggy tires for a 2.2 rim often have an outer diameter of nearly 3.5" so about slightly over .5" tall sidewall which is a little to big for me. I hope that helps.
car54
Looking at more trail or rock climbing off road tires, 1.9 size wheels and like 4.19 or 4.7 OD tires. Hope it clears my end up, junkGTZ sounds like it might work but will be tight right? Not sure if 3d printed wheels will handle it, you know.
JunkGTZ
I've not dealt with 3D printed wheels, or for much of anything else for that matter, and my one experience with a 3D printed object gave me the impression that it's good for low stress parts but not for something that might be subject to some forces. As for tires, you might check out the A-Main Hobbies website. They seem to have tires of all sizes (except the size I needed - onroad touring car/GT) and most especially for off road and rock crawlers, etc.
jns65wt1hy6kkn6
my experiences...
hex mounts: ok. takes some terrible printing to mess that up, and easy to hand fit afterwards anyway
pin mount: can work on larger sizes (1/10 pins) but expect some hand work.
axle mount (like D axle mount): forget it. 99% of the time printed wrong and will come off center when you try to shape the grooves to fit. i have a pile of useless losi micro wheels that never got printed right in the mounting point. printers cannot make the proper D shape on 2/3mm axles
