Axial SCX10 II Ford F100 Supercharger
PintoPower
A little project we just finished. If you ever thought your scaler needed to be heavier, have a higher CG and need way more electronics and complexity then have we got good news for you! This supercharger for the 1955 Axial SCX10 II Ford F100 has working butterflies on the scoop, working throttle linkages on the carbs, a "working" pulley and all the datails you need for your scale F100 like fuel lines, vacuum lines and mounting holes to attach wires for the AC kick ups and choke. Excessive? Yes. Please see the installation video below for the complete build. This can be located on Shapeways as well as MyMiniFactory.
Parts on shapeways:
AS2002-0A Axial SCX10 II F100 SC Mount
http://shpws.me/RUe0
AS2012-01 Axial SCX10 II F100 Supercharger
http://shpws.me/RUe1
AS2013-0A Axial SCX10 II F100 Air Cleaner
http://shpws.me/RUe2
AS2013-0A Axial SCX10 II F100 Detail Parts
http://shpws.me/RUe6
BOM List:
1. 3mm steel rod, 28mm & 34mm
2. Mabuchi 130 motor
3. 2 M3x8mm countersunk machine screws
4. 10x m3x6mm screw or m3x6mm set screw to hold down engine mount
5. Tube - 5mm ID, 6mm OD, cut to 20mm
6. Micro Servo - Case Dim 22.9 wide, 22.8 deep, 12 tall. See the image in the video. the depth offsets may vary. Spacers may be needed.
7. 1mm thick rod for servo to carb linkages
