Bead lock assembly made ez
I cant be the only one who has thought of this .....So I got tyred (see what i did there ) of trying to put my bead locks together the hard way either with longer then stock screws or squeezing till my arthritic riddled fingers ached just to fail at starting a nut. So i figured a spare stub with dive pin and 12mm hex was the solution i put rhe bolts into the hub placed tape on the the hub to to hold said screws and then assembled the bead lock. Lining up the back and front of the wheel then tightened down the wheel nut being careful to line the bolts up and bam wheels halfs are tight together and squared up. Install nuts do next wheel. Figure i share this gem with yall
Sent from my LGLS991 using Tapatalk
