Bending sheet aluminum
E
ecoli
Going to try some tubers with aluminum belly pans on them. I'm picking up some 1/16" sheet aluminum, probably 5052 since it apparently takes a bend easier. Anyways, I'm wondering what people are using for bending their aluminum? I don't own a metal brake, but I'm suspecting most others don't either, so what's the trick? Vice and hammer?
Chris
HeyOK
HeyOK Performance
If what I am working on isn't very wide, I use a vice and a hammer. Often I will use a block of wood to push on the aluminum, just using my hands, but if needed, I'll wack that with a hammer and the wood keeps the metal from getting marked up too badly.
M
madhatter
Princess Auto also has a little hand break that you can mount on a table. I've got one here and its a god sent alot of times. They are usually on sale or at least quite often, but aren't much money regularly.
C
colonelangus
bending alu
i used a press and clamps because it was here ,but the break is the way to go.
E
ecoli
We've got Princess Auto here, I'll have to check it out. A table mounted one sounds like it would fit the bill. I'm used to the big shop versions. Thanks!
