Building a PG4L
Vladimir Putin
Ok, I got it all planned out, I just need to know what is the best motor is... The only specification is it needs to pull lots of weight...
Will this work: PULLER PRO BL 540 XL
pardonmyn00b
What the hell was that?!
Since this thread isn?t a build and only has a question about a motor I moved it to the right spot.
You gave no detail about how much weight or what turn motor it is but proper low gearing will create higher torque allowing motors to pull heavy weight.
The answer is: probably
