Hakosuka GTR
Lem
that looks fantastic.
If you wanna try out 0.15mm aluminium sheets you can get them at a local print factory. It is usually waste they have to recycle and pay for, at least here in my country. I get that stuff for free just asking if they can give me some plates for modelling.
Frederik
That's interesting, here they actually sell this aluminum to recycling companies for lots of money.
One other way to have an aluminum look and have some thickness, you could use air ducts aluminum tape (actual aluminum with an adhesive backing) and put several layers.
It is thin enough to form to crisp shapes, but much thicker than regular aluminum foil. So you could form them to crisp details and they would stick, then you add a layer and form it again (put the tape in perpendicular direction), maybe that would end up with a nice aluminum piece.
Ghostpig
This looks incredibly realistic!
Thank you!
Thanks and thanks for the tip! I have ordered some 0.15mm tin plate and I'll try that first.
That's an interesting idea. I may try that if everything else fails. But I'm going to paint it so it really doesn't matter what the material is.
I have now started making the dummy S20 engine. Some styrene, brass tube, M0.8 and M1.4 bolts. I have used my Tamiya Skyline 2000 GT-R scale model kit engine as a reference and a bunch of pics that I found in the web. There will be other stuff and details too. But next I'll tackle the exhaust piping.
Other news is that I'll re-do the electronics layout. That's because I have bought some seats and I want to do nearly a full interior. Battery will go in the trunk and I think I'll have to cut the trunk lid open too. Might be a bit tail heavy and tail happy to drive but I have a smaller 2s lipo if it's too hard. There's also radiator in the front. I got the RC4WD radiator. It looks nice but it's quite wide. It fits but I might have to modify it. The dummy engine needs to be shaped to fit better.
2Beers
It's me again.
Beautiful work on the engine. It's a thing of beauty no doubts.
Chassis coming along super fantastic too.
My eye's are happy ::2thumbs
Ghostpig
Your engine looks awesome! Love the front view with the radiator.
Thank you!
Thank you! I'm glad that I was able to please your eyes.
Fantastic! Great job on the insides... where's the steering servo?
Thanks! Servo is behind the driver's seat. Right side that is.
I've got some more work done but now I should really focus on how to attach the body.
I have exhaust piping.
The engine has some piping too.
Hood details done in 0.15mm aluminium and glued in place.
And I made a new smaller radiator that fits better.
Ah yes, I've found the servo now, very cunning!
Engine details are gorgeous, this is coming along beautifully!
Frederik
Very nice engine details and underside view! I would really like to see a video of the moving parts, cycling the front suspension, rear suspension, steering it etc. After such nice work designing it all, I would love seeing the geometry do it's thing.
And that is a very nice driveshaft, is it the RC4WD ultrascale or something else?
Ghostpig
wonderful detail ::2thumbs
Yep, this is amazing.
Incredible attention to details!
The underside and that exhaust run look awesome Ghostpig!
Eye popping details!!!! Love that engine work!!!
Thanks everyone!
Thank you, Frederik!
I'll try to take a video next weekend. And the drive shaft is Hercules Hobby 1/14 tractor truck aluminum drive shaft.
I have started making the interior. Dash and center console under construction. I will route the motor/esc wires through the center console. But I should really try to get the body mounted. I've been postponing it too much.
Chafa
Thanks everyone!
Here's how the diff goes together.
The pinion and ring gear are from SSD, locker is 3d printed to fit Tamiya TT-02 joints. M1.6, M2 and M2.5 screws. I used some dumb sized bearings that I didn't have while designing the locker, so I had to use styrene tubing to fit the larger bearings but it works though. Needs shimming.
Here's the gearbox.
RC4WD R4 transmission gears, M2.5 screws.
This is fantastic!!
Ghostpig
Time to get this Hako done!
I've finally figured out how to mount the body. I'll use some magic... or magnets. Those two always mix up. Nothing to show yet but soon I'll make something.
Also I've been tinkering with the hood hinges and today I made a proto hinge out of 0,3mm tin plate.
Frederik
Very nice piece! Did you cut it freehand with regular tools? It looks very even and straight, looks like it is laser cut!
