M548 tracked vehicle - Cooper
cooper
more:
These LEDs were a PITA to mount. When I did the rear section,didn't thought in practicability to mount lights. But was doable:
It's a printed taillight with a real piece of stoplight inside :)
Headlights and winch:
And this:
You guys don't imagine for how long I'm waiting for that extra bit of patience to fit the weatherstripping in the windows and then, the wipers
first 3 are done
cooper
Woooow!! Very nice Cooper!! I love it. You take care of all the details. Nice work ::2thumbs:luv:
It's been a while after the last update. Nothing much has been done. After the front and rear windows, left the corner windows for last.
Honestly, I was expecting them to be hard but not that hard. Starting by the fact I needed to heat form the curved windows and then do the weatherstripping . Quit the idea of using rubber and make a paste with putty and black paint to apply and close the gaps
Could have turned out better but will do
Henry
Your half track manufactures left me with an inclination that i require one of those to however not a half track, i ought to go to a full followed vehicle, the Unanimous assemble it's in somewhat of a halt since it needs a decent measure of metal manufacture and i required a polystyrene work to do on the week...
http://fromcuptocrop.com.au/
cooper
You have 2 solutions to not have the trouble i had with mine:
-you can build on top of a 1/16 tank chassis;
-if you have acess to a 3d printer, iceman88 is releasing the files of his 3d printed m548 on Thingiverse
cooper
well,too much time without updates. M548 was nearly considered done, only needs the smoke generator fitted and paint the hull but there's something more important.the henglong gearboxes are not up to the task.I'm already on the second set.
Working on new system using these gearboxes:
37mm-Diameter-Gearbox-Eccentric-Shaft-Large-Torque-Speed-Reduction-Gear-Motor-with-Metal-Gearbox-gear-geared.jpg_q50.jpg
Ordered a 30:1 to test
Thought of machine the structure but 3d printing could do the job
cooper
First of all, I'll not say that this was my original creation
There's a german shop( https://www.modellspiegel.com/) who created and sells these gearboxes for 1/16 tanks:
I had several ideas for the new drivetrain and the chosen was heavily influenced by this layout above
But I the time, I'm not in condition of forking out all that money and also like to do things myself as much as possible
To the build,this is where it sits now:
Tomorrow will do a test trial to see if the ratio it's good or not, and then order the other gearbox
cooper
First trial of the setup on 3s. It's so good when things work at first try. Unfortunately, the gearbox it's too fast(33:1,actually), I've already ordered a slower one. The only bad thing was that the bores on the gears are a bit off center, that's why it sounds that way
luxarsKetch
Weathering is addictive.
Tracked vehicles take such a strong a place in my heart. Great build, enjoyed every page. Hope to see more progress and vids!
cooper
Thanks for the kind words and to bear all these pages. Tracked vehicles, always wanted one. Maybe I should had bought one but fortunately, this one has been accomplished. Recomend everyone to try one, so much fun
cooper
Don't you just hate when you go on the local junkyard get replacements for your 60's tracked truck and they even got the right color?
Seriously,this one was printed on PETG instead of PLA. The odd color was on sale at the time. It will be painted OD anyway
cooper
Good news everybody!
Things have been quiet but I'm working on the new transmission as parts arrive.
The test 33:1 gearbox was been replaced by twin 56:1 gearboxes and got the right pinions so was a matter of making the shafts, spacers and assembling everything
The transmission structure will be replaced by a V2 version that fits better on the hull
cooper
I thought the truck would be ready by now but I've had a few setbacks. For now, I can show you the drivetrain working outside the m548
It's not a feat of engineering but I'm pretty happy with it. The old one was loud
TheGamer
The setbacks were about parts availability, because the engeneering is all there! Congrats my friend! :D
cooper
That's awesome man keep it up
Thanks! I'll try to improve the looks now because there's not much else to do
The setbacks were about parts availability, because the engineering is all there! Congrats my friend! :D
Yes,it was like the Unimog all over again. Must do simple trucks from now on :p . Next time we'll trail together, you can try this improved version
there it is,assembled and working. Just need a cover to reduce some noise and prevent that some LED wires don't get caught on the gears. The electronics are not in place because I'm about to take everything out to paint the hull
There's some video.Sorry about the background but I can't go to the woods right now
cooper
Dollhouse stuff:
Thought that the operator needed some goggles for his helmet. The first idea was to scratchbuild everything but my Dremel broke so I've copied the goggles' frame from the real army model and 3d printed it.The lens are from a bit of clear package plastic and the strap is a strip of bicycle inner tube
