New 1.9 Aluminum Beadlocks at GCM
generis
New stuff! All these rims are machined and include a full set of 4 as well as matching hubs!
We offer 5 lug and 6 lug versions of each!
The site listings are here: http://gcmracing.ca/viewcategory.php?groupid=41
Using our trusted beadlock spacing and design, we now offer these 1.9 size rims, with internal recessed beadlock screws, fitting any knuckle and lockout combo we can find. These rims are completely billet aluminum machined.
The fully machined 12mm hex seat will sit solid on the axle and with the -1.1mm offset your tires will tuck right in. These rims feature a full width of 26mm measured outside the lip, and will beadlock all the regular crawl tires from all manufacturers. This means the tire will fit more square on the sidewall, reduce puffy foam issues, and make a more realistic tire tread print. Check out this link ( https://www.facebook.com/gcmracing/posts/3229112103841681 ) for info on tire foam trimming for perfect fitment on wide tires. Also fits Pro-Line tires, and everything else we have tested.
Includes all hex hardware, wheel components, and fits all 12mm hex for 4 wheels.
Includes 6 of the M2 bolts for center cap per rim.
(bolts can be easily replaced with scale M2 hardware)
Includes a full set of GCM Simple hubs
Fitment notes:
Outside of rim to hex face 11.7mm.
Inside of rim to hex face 14.2mm.
Total width 25.9mm.
Outside diameter of rim 54.5mm.
Sent from my Pixel 3a XL using Tapatalk
