Tommy R
Hey y'all,
I'm finally working once again on a project I started years ago and thought I'd share it here. For years I've been mesmerized by the European semi truck scene. We mostly only have crawler events where I live, however. Fearing the limited use of a RWD truck, I decided that an all wheel drive version might serve me better. It won't be as capable as a crawler, of course, but it hopefully won't get stuck every 10 seconds, either. :)
I decided I wanted something that would be a bit of a combination of the styles of these two trucks:
I picked up a King Hauler in late 2016 and got it built in stock form.
In the process of building, I decided to put some super heavy grease in the diffs. I didn't want the diffs fully locked, but fully open would suck. So far, this looks like a great solution!
But I need to have a driven front axle if I'm going to have a 6x6, right? TLT front axle to the rescue! Of course, it got the same diff treatment as the rear axles.
With some Hi-Lift leaf springs and some spacers to widen the hangers and shackles, the front axle bolted right in.
Another Hi-Lift spring was sacrificed to help tie the bolts together because they run all the way through the axle to secure the leaf spring to the housing. Yes, I changed the hardware later on. :)
This brought up a big challenge, of course. How do I get power to the front axle?
