Project Traxxas slash trophy truck custom build!
LoganLemx
So I had a complete slash and a parts slash laying around so I decided to mash them together to create a rear solid axle trophy truck. at the time of me posting it I have already started the build. My ideas for it is a crawler rear solid axle and a custom-built cage. I have never braised before so bear with me it might look bad when I get around to it. At the time of me posting this I have located the ESC receiver and the transmission. (See picture below for reference) moved the transmission to where the ESC used to be. I had to raise it up a little bit after I dremeled it out because of the sloped sides. To be able to use one drive shaft going to the rear I had to J-B Weld the diff together so both axles would spin at the same time. For the rear axle I was planning on using a cheap Amazon axle it was like 40 bucks so I thought I would give it a shot. I had to dremel out the area where the drive shaft is so that it would clear the edge on the chassis. How do you insert a image from your phone I sat here for like 30 minutes trying to figure it out?
Carnitas
I love a trophy truck build! On uploading pictures, you can pay for a membership, or you have to upload your picture to an image hosting website and then copy/paste the link.
Or use the Tapatalk app.
This subform is for scale accurate builds. Moved it for you.
LoganLemx
Well I figured it out!
Sent from my SM-A115U using Tapatalk
LoganLemx
Bought over 15 ft of tubing and some plates. About $50USD. Might be too much if so I have other ideas for it.
LoganLemx
Today's update I realized I still need to buy my rear axle and my links. I am planning on building a cage out of wood first then the finished product will be aluminum and brass. Well I found some inspiration for the cage (see pics below). The chassis length now is way too long. I am going to cut it down and do a side ways battery tray. I feel it will look more scale that way. The pics below are the real things I will try to incorporate things I like into the build. How much should I chop off? (See pic below for what I think)
LoganLemx
Todays update,
So I decided to start from scratch. I am going to build my cage and chassis first then figure out how I am going to do the transmission, electronics, axles, etc.
Panther6834
Todays update,
Probably smarter that way. Not that I've ever built something like what you're trying to do...but, if you check what others have done when scratch-building rock racers, I believe that's the same "order of things" they typically follow. I'm not even remotely interested in attempting anything similar...but, I am interested in how your project comes along - will be watching.
~ More peace, love, and kindness would make the world a much better place
LoganLemx
Hi guys sorry I haven't posted in a little while I've had other things to do and I took a little break. So far I have built the wooden cage templates only the cab. I returned the original tubing I bought and decided to go the steel route. I found some steel on Amazon for about 12 bucks for 72 inches it's a pretty good deal. The diameter is 3/16in. Well I'm editing this now because I accidentally hit post. I am using some wooden skewers for creating a frame. I feel and helps if you print out the templates to scale. To hold the skewers together I am using a hot glue gun. I tested it on a couple bodies I have and it's not fitting but I feel it doesn't have to to look good. I'm thinking it might fit a crawler body if you can test them your local hobby shop. I think I would like it without a body anyway. At this point I would need to know if I should do a four-wheel Drive at the point of posting it is pretty much set up to be a four-wheel drive system if I wanted it to be one. Tomorrow I plan on starting the front bumper and that area. I am planning on using some Losi Baja Rey front A-Arms. Along with a metal Concepts rear axle. It comes in handy if you have somebody who can make you metal Parts on a mill. The only hard part about that is buying the mill and creating the design. I am undecided if I'm going to do sway bars or not. I think it'll add a lot of scale realism but I think it takes a lot of math and thinking which I'm not really good at LOL. The rear linkage four link using Losi Baja Rey links. Thanks for reading stay safe!
Logan
LoganLemx
Wow I haven't posted in a while. I took a little break I started my brazing and metal work. (See picture) I'm using 3/16 in brake line as my tubing so far it is working good. I have been using 1/16 in brazing wire that is coated in flux. Thanks for reading stay safe.
