Rc4wd wagon wheels cutting ripsaw tyre beads.
dingo20
Hey hey,
I'm running rc4wd black Wagon wheels and ripsaw tyres on my dingo and I having a problem of the bead being cut along the edge of the bead lock on the rim.
Any one had this issue before and how was it rectified ?
Sent from my SM-N9005 using Tapatalk
RC4WD wheels are designed to work with RC4WD tires only. So, your only solution is to not use non-RC4WD branded tires.
bonards29
when i used different tires you will have to measure the thickness of the rubber on the the bead. you can grind the ring to give some room for thick bead tires if not this will happen.
Metal Masher
not entirely
i make my own inserts out of pipe that are beveled on the inside to match the tire bead. I have almost 5 years on my TSL tires and steel wagon wheels without any problems.
pardonmyn00b
What the hell was that?!
I'm pretty sure RC4WD ended up making a ring to fit the proline and Axial tires. Of course I can't find it on their store right now
