Maybe wet sand with super fine grit then polish with rubbing compound? I recently used a 3m headlight polishing kit and thats all it was, just a few different grades of sandpaper and autobody paint polish.
It removed black scuffs and scratches, left a nice clear finish.
If not, maybe good ol brake fluid would do it.
Can you keep us posted of the progress on yours?Thanks I'll try the sand and buff deal.
I can cover the lettering in black vinyl but was hoping for a clear solution as I'm not much of a tint guy.hey Ken don't your CC windshield decals cover it up?
you could allways just paint a band of black over it to make like a smoked windshield band
I don't have one of these windshields to look at up close, but being a bit of an auto detailing aficionado, I'd try some acetone. (Your wifes fingernail polish remover should work they are usually acetone base or something similar.) BUT USE CAUTION!! Just wipe it once and let it dry, wipe it once and let it dry. If you wipe to many times the plastic will get soft and smear. You'll notice right away if it's going to work, don't over do it. You'll probably need to give it a quick polish or wax if it starts to fog. Boat wax is the best because it's made for acrylics, gelcoats, fiberglass and plastics.
The mechanic side of me believes the brake fluid could also work. DOT 3 or 4, not 5.
Hope this helps.
I know it sounds stuped but try mayo ,
oooh god, be careful with acetone, just put a dot of it on the letters before dabbing it all over!! my wife got a drop on a wooden coffee table and it screwed up the varnish on the table by the time we ran to kitchen to get a paper towel to clean it. I'd be very afraid of using it on a rc windshield
