Scale Driver JKRC Painting 101- Painting the JKRC Scale Driver
UNGLEWD
Detailing the JKRC Driver Head
In 8 easy steps
1. First, apply 2 even coats of your preferred flesh color. (no need to worry about staying within the lines, each stage will cover and clean up the lines from the last)
2. Using a slightly darker shade of your flesh tone add some shading to the face
3. Using Gloss White carefully paint in the eye balls
4. Eye brows and hair color is next, use a fine brush and your hair color to paint these in. While you're in here, if you want to add some more definition you can add facial hair.
5. Using your iris color create two even dots of color on the eyeball. These can be off center to make it look like he's looking to the side but make sure these are even. Take your time otherwise he'll be cross eyed.
6. Take your Black and a fine tip brush, create a pupil dead center of the iris (this has to be even and of equal size but the dilation of the pupils is up to you).
7. Choose your hat color, be sure to use a matt finish...fabric isn't shiny!
8. Next step is like magic, eyeball shine. Use a fine tip brush and gloss white to put on a few small dots to simulate reflection. This makes the eye's look shiny...a little twinkle! Note: Be sure to put the dots in the same area of each eye, the reflection would come from a consistent light source.
Thank you for your purchase
JKRC
