scx10 from 12.3" to 13" wb
matty85
There is a bunch of youtube videos on it. Most people us 8/32 threaded rod you can get pretty much anywhere and traxxas revo rod ends. In theory you can use the stock links for measurement, add 0.35 (8.89 mm) to every stock link and you should get pretty close (13-12.3=.7 .7 divide by 2=.35) This will lengthen each side equally. I suggest a digital caliper when measuring.
matty85
No problem, pretty easy if you own a rotary tool, once u do a couple the rest at pretty easy
