SCX10ii Body Mounts for the RC4WD K5 Blazer
RexRacer19
Let me 3D print that...
Mod19RC is now offering a new option for mounting the RC4WD K5 Blazer or Pickup Cab to the Axial Racing SCX10ii chassis. These mounts are printed through Shapeways using SLS Nylon for strength, durability, and quality. They attach directly to the SCX10ii chassis using the factory screws.
These mounts are designed with scale builders in mind and feature a unique body mount tab that can be mounted four different ways to help get the exact look and tire fitment to suit your build. They are ideally suited for builders using a front motor conversion. If you plan on keeping the stock AX10 transmission and using the Blazer interior, note that it will need to be modified to clear the spur gear and back plate.
The left and right sides must be purchased separately (to keep print costs down) and each includes a body mount tab. Additional body tab sets can be purchased separately if mounting multiple bodies to the same chassis.
Pricing for the set (both sides) will be $48.98. You will also need to provide the (4) stock M3 x 8 screws from the Blazer body along with (4) M3 x 10mm Flat Head Socket Cap Screws to attach the body tabs to the mounts.
Hit the Shop Now button at the top of the Mod19RC page or follow the link below to the Mod19RC Shapeways store.
https://www.shapeways.com/shops/mod19-rc
guillote68
Hi, im in the middle of a trade with a friend, and i like to know is this body fits on a Dingo chasis, without the motor and transmision change to front? is that possible ? you lost the interior and seats?
Please i need some help.
regards
Guillermo
RexRacer19
I am not super familiar with the Dingo chassis, but I believe it has the 11.4" wheelbase and is based on the SCX10. That should be right for the Blazer body (11.3" so small difference). In order to use the stock transmission with the interior, you would need to cut down the plate that the spur gear cover attaches to and you would also have to modify the interior at the back of the seats for the spur gear to clear. I hope this helps.
