Styrene vs ABS
bajslowski
Hi! Never tried my hands on building with styrene before. As I?m searching for materials I found Greenstuffworlds plasticard which is labeled as ABS. Is ABS a viable alternative to styrene if I want to try to build some louvers for my lexan Volvo body? It?s so much cheaper. Can?t seem to find much info on this.
pardonmyn00b
What the hell was that?!
Polystyrene has similar properties as ABS (Acrylonitrile Butadiene Styrene) but sometimes it?s hard to get them to work together with our regular solvents. Something to do with the molecules of the styrene in the form of ABS. I?m not a scientist though. It will work perfectly fine though for your build.
bajslowski
Great. Thanks! Would you recommend buying "proper" styrene (Evergreen or such) if I would build a bigger project in the future? Or should I stock up on the cheaper ABS when I'm already at it? As long as I'm not mixing the two it would be fine?
pardonmyn00b
I'd recommend going for the polystyrene. If you can find a plastic supplier near you, large sheets of high impact polystyrene can be had for incredibly low prices.
bajslowski
Thanks for your help. I'll keep this in mind for future projects. For now I've ordered a cheap variety pack of ABS to try it out.
Styrene sheets should be cheaper than abs in the same thickness.
I build with ABS. Glue it with acetone and slurry. Its a long wait in between pieces as you wait for the acetone to ?dry?. Its tough when its done.
This is what I?m still currently busy with:
Samil 20 4x4 utility Truck
https://r.tapatalk.com/shareLink/to...ead.php?t=609689&share_type=t&link_source=app
Thank you! This is exactly what I've been looking for. Good looking build. How bad is the acetone to work with? I'm assuming you'd want to work in a well ventilated area as with most other solvents?
wesmade
If you check eBay, you can get descent prices on Styrene. I don?t have a plastics supplier in my town, so I need to order it. I typically get 24? x 48? sheets. It?s about $25 shipped for .060? thick. Soooooo much cheaper than the Styrene at the hobby shops. Plus you can get bigger pieces.
Wes
