TF2 high clearance skids
RC Addict
These brackets were manufactured by Goldwing to give you the same clearance levels he got and and we are a licensed dealer of them for you.
This aluminum bracket is designed for the single speed trans and tucks the transfer case up in tight to the chassis.
You will have to modify the rear battery tray either with spacer or cut out a space for the rear drive shaft.
This does not work on the 2 speed trans as the front drive shaft hits.
Buy Here - High clearance tf2 tcase bracket
