weld Aluminum
scorpion
Just hoping that someone out there has some info on how to weld aluminum? I am looking to build some custom parts for my "Betty" crawler and I have some aluminum stock but need help with the welding or joining some parts.
C
Code454
you are able to get aluminum brazing rod to braze it, or you could take it to a metal shop and get them to weld it up
S
SlowKrawl
I have never brazed aluminum before, but I don't think it works very well.
Keep in mind, if you do decide to braze it it melts at a very low temp, I forget the exact number but a mapp gas torch will melt it.
Do you have the set-up to weld it?
scorpion
weld aluminum
hmmm well thanks for the help and I think I can get rod locally and what the hell I may just have to try it and see nothing ventured nothing gained so if I will see what I can fine for supplies and let everyone now what happens.
Randy
J
jpfabricator
Check out "TM Tech" on the web. The tin man has books, and classes how to oxy-fuel weld aluminum. Alot of great info for a reasonable cost.
J
jhedsy
Youtube it? I'm always amazed what I can learn from there.
T
tgenial
You can watch
If you need traduction, I'll do it :biggthumpup:
You need Castolin 21 decapant stream or equivalent, aluminium intake and a bi gaz( O2+acetylene or C4H10(butane)) torch
Enjoy :rock:
