What To Do If You Do Not Want To Wait For Redcat's Bed Dancer!
joe122
Hello all!! So....those of you
who are looking forward to the new Redcat Racing mini truck bed dancer here is my impression of major impatience!!!!!
Wanting to stay with the mini truck scene I found a set of files on Cults for an '90's S15, after about 60 hours of printing the various body parts here is the body. Yep, will need a lot of body work!
Now, the bed, using some photos I found online and inspiration by @Nikaidocustomz on IG I have come up with a Z rack that looks like after some manual testing might work! Waiting for a 6 channel receiver to test it out before I continue with the suspension and body work. Open to any constructive criticism!! #minitruckscene #minitrucks
joe122
Little update on my GMC S15 "baby square body" bed dancer. This is a resin print, my 3rd body that I have printed. NO WAY was it anywhere ready for paint. these photos are after quite a bit of body work, sanding and high build primer, first coat. But I have a roller!!! Added the cowl hood, going to add a front roll pan as well, lots of body work to do and I need to wire it up and test the bed!!!
Frizzen
That's already looking pretty sweet!
Am i seeing a 3 stage Z-rack on the bed?
I know you already mentioned doing both Rollpans, any thoughts on things like spoiler, tonnau cover, truck cap, battery racks, pumps, randomly shaved stuff, frenched stuff at weird angles...
I didn't know Redcat is doing one too.
joe122
Cool!
I hadn't even heard of the Redcat one until you started this!
Yep, in conjunction with Vevries! Thanks!
Yep, Jevries has been working with them, late '24 release I believe. Yes, 3 stage Z rack, will be testing it today in fact. Will have tonneau, spoiler is a great idea, did one on a 1/10 scale K10 before. Bed accessories are a possibility, shaved handles - yes, frenched items like license plate, maybe!!! Thanks!!
Kear
Bleb
I can't see what I assume is suppose to be a video...But knowing the work you do I can imagine the result is fantastic!
I'm more a fan of the rounded/bar of soap lookin' later S10s, but the earlier square ones have a charm all their own!
But lookin' closely, is the cab shell printed using an FDM printer or is it also resin printed? I ask because I see some small flaws in the print that look like fairly common defects with an FDM print.
joe122
The way it wiggles makes it look very realistically like fiberglass!
I think it's a lucky visual outcome!! Thanks!
It's a resin print, has more body work underway currently, just working out the proof of concept first. I don't mind the "boxy" S10/S15's, rounder would be cool too!! Thanks!!
joe122
Resin prints are not easy to get paint ready! If smooth is your thing than significant body work is required IMO! So, S15 bed dancing Sonoma has had some body work and a few mods done. Added a front roll pan and modified a '68 Camaro front bumper for it. Shaved the door handles, molded the rear roll pan into the tailgate, frenched the license plate opening into the tailgate and added a little spoiler. Need to add the tonneau cover, address more body work and get ready for color.
joe122
Love color day!! Was time, enough sanding! S15 Sonoma has got color, bottom is #tropicalglitz Cosmic gold, top is their Shifty Psycho Inferno with Sunburn Metal Flake on top of both colors. Used UPOL 2K clear for topcoats. Now cure and possibly wet sand!!
Kear
Bleb
...That color combo makes me want a burger and fries...dunno what it could be...
Jokes aside, looks like all that prep was well worth it!
joe122
Assembly, started to get things together, still have rest of wiring, interior/glass, bed cover etc. Sonoma / bed dancer is close to grabbing a video. Added a bat wing vintage style air cleaner, a bit of engine wiring/fuel line and added some chrome to the modified '68 Camaro front bumper. After stretching the frame, it got some #tropicalglitz Cosmic Gold as well. Used a few #scalemetalsupplies tabs to get things bolted where necessary.
ItsTooBright!
They shoot canoes don't they?
Nice! I hope the bed doesn't break, I have heard that resin can be brittle. (unless of course you are using ABS resin)
